I'm wondering about converting mine to an automatic, its a 300tdi and i thought of using a 300tdi disco auto setup as donor parts, anybody any experience of this?
cheers.
Have a look on LR4X4.com or speak to Ashcroft Transmissions.
I believe the conversion has been done plenty of times. Iirc the transmission tunnel is quite an expensive part as I think it was only used in some of the limited edition models which were autos.
Colin
Edit: I've just had a quick look and Ashcroft do a conversion kit. The page will at least give you some idea of the parts required.
if he's able to fabricate a remote shifter then that solves the problem, its like putting a disco box into a defender you just need to fit the correct shift unit
