BrokenBiker
- Newport, South Wales
right, I am now fed up of trying every CAD/Moddeling program out there to see which is best suited to me.
I am currently finding inventor fusion quite easy to use, it does what I want first time and animating things is simple, which is what most of my modelling is done for, to prove something before making it.
2 things I am stuck with are:
making threads on a shaft i.e. a bolt
assembling a shaft in a bushing so the shaft will still rotate, but not move laterally. currently I have a handwheel that operates a sprocket, connected via a shaft and the shaft runs through a grounded block, the block cannot move, but the shaft will move in the y axis as well as rotate and I need to lock it in the y axis so it only rotates, if you get what I mean.
