Eric the chicken
- North Beds, UK
A neighbour of mine has a problem with his Audi A3. Central locking has failed on the driver's door and rear offside passenger door. After investigation the wiring loom from the driver's door to the 'A' post has two broken wires and several showing signs of chafing with the copper inner exposed. The wires pass through the 'A' post via a connector block. In order to repair the wiring, need to detach the connector block from the A post.
Before attacking the connector I thought I'd ask if anyone's taken one these connector blocks out. The connector has a mauve clip or slide at the top which looks as if it may slide move, but after a bit of pulling and pushing it hasn't budged. As I said before I'm not keen on using too much brute force and I've already got the ignorance. So any help greatly appreciated
Regards Eric.
Regards Eric.
