CompoSimmonite
- Werrington, Staffordshire Moorlands.
Last year I cut a load of new scaffolding poles into the lengths required to build a basic 10' x 8' frame for a new shed / workshop with pent roof. The proposed site slopes so it'll be on "legs" concreted into the ground meaning no need for a slabs or concrete pad base
. I've got loads of KeeKlamps so all the joints are sorted.
Plan is to clad both inside and outside of the frame with insulation in between. That means timber bearers need attaching to the scaffolding poles. When I built my carport I used tight fitting saddle clamps and whilst these will work again the number required means it'd be a very expensive method so have been trying to think, without success, about alternative methods of attaching timber to scaffolding poles.
Best I can come up with is drilling 50mm holes in 4" x 2" timber lengths so they will slip over the 48mm dia poles. Hopefully the couple of mm different will help with any inaccuracies
. Another thought, probably better, is similar - clamping two lengths of 2" x 2" timber together before drilling holes so they can be fitted either side of the poles and then screwed together.
I have brain fog (unfortunately becoming more common / normal for me) today and can't think clearly so wonder if anyone has other suggestions for attaching the timber to the poles ?
Cheers.
Paul H
Cheers.
Paul H
