Ok So I do know this is a welding forum but there are some wise and clever people on here so I thought I post this.
Just picked up an atco cylinder mower. Got it home and it seemed fine for the first 10m them the blades stopped rotating but the drive still worked, then by the time I'd got back up the garden the drive stopped as well. When I opened it up and cleared out the humungous amount of grass inside I saw this.
Seems like the couplings from the motor and drive shaft don't meet? I can't decide if the coupling on the left side has either broken its fingers off or slipped up the shaft towards the engine (seems tight even with the grub screw loosened) or the drive shaft on the right is not set right.
All works if you wedge the black rubber piece between the two but got a feeling that's not really fixing the problem.
Anybody come across this before?
