visor_down
- UK
Hi all
I mainly weld thin stuff and have a 5%CO2/Argon mix for this, I need to do a few bits using thicker stuff, would the current mix be OK for this or do you have to use a higher content of CO2 or even pure CO2 when welding 3-8mm?
Where would you consider the cut off to be in terms of thickness for 5%CO2/Argon mix?
Part of what I need to do is join 8mm round bar (which i will bevel) and weld some 10swg weldmesh on it.
Although i don't have any 8mm bar/sheet stuff to do in the immediate future would be handy to know if it could be done with the mixed gas.
Welder goes up to 215 amps which I think is about 7-8mm so just interested to see where the gas becomes the limiting factor.
Would there be a need to increase the flow of the gas on the thicker stuff ? (usually run at about 10lpm on thin stuff)
Cheers
visor_down
Cheers
visor_down
