Johnseat
Well as the title suggests, i've got around £200, I could stretch a little for a better MIG rig but around £200 is ideal.
I'll be using it for car body work only, I should imagine a maximum steel thickness of 2mm.
Now i've had a welding course, done stick, MIG and brazing.
I'm ok at welding thick metal (2mm+) BUT when I used my mates cheap MIG
with only 4 power settings on 1mm body steel, I either blew through or pigeon'd on the surface!!
I really want my own welder as i'm getting into putting a mk2 Golf GTI back to mint condition.
What do you guys recommend, i've searched the forum and discovered that Clarke get good reviews!!
My only problem is the low end ampage, surely I need as low as possible for thin sheet or can I weld 0.5mm to 1mm using a 30amp minimum welder?
Cheers John
Cheers John
