andypocock
Hello Gang
Having read through a lot on this site I decided to upgrade from pub gas to an argon mix.
I got a rent free bottle deal from MigTigArc in Portsmouth. JUst over £100 with the deposit and everything but only £18 per refil from here on so it doesn't look too bad.
The problem I have is that my old reg (rated high enough for Argon btw) has a HP gauge in psi/bar as you'd expect and the LP guage is the same but obviously with lower readings. So how do I get an accurate flow rate? Is there a ballpark outlet psi that will relate to about 12l/m?
I suspect I'll end up buying a new reg with a flowgauge but I'm in enough trouble at the moment as it is - she saw the receipt for £102 for the gas bottle.
Many thanks
Andy
Many thanks
Andy
