Having learned to butt weld thin aluminium with Oxyacetylene in the days of B/W 405 line TV and trouser turn ups I have worked my way through Arc and MIG welding on cars and my multifarious engineering hobbies. The appearance of economical PWM circuitry has now enabled me to purchase a TIG machine with which I hope to achieve similar results as Oxyacetylene albeit DC so no aluminium.
Using my suppliers recommended argon gauge and flow meter set up however, I experience an off-putting burst of Argon each time I start a run. I attribute this to the fact that the gauge is factory preset to 2 bar which feature allows a volume of gas at 2 bar to build up in the line between the gauge and the machine solenoid valve. This build up of gas rushing through the torch every time the solenoid valve in the machine opens until the pressure up and down line of the flow meter equalizes. This must waste gas to some extent I guess. This does not happen with my MIG setup where I adjust the flow using the pressure regulator rather than the flow meter valve.
Am I being too sensitive or, as I believe, should I swap the preset pressure gauge to an adjustable type?
Cheers ikb
PS As a newbie I hope I am on the right forum.
Cheers ikb
