So i've been having a bash at getting my lathe set up properly.
I still need to get myself a length of precision ground bar (unfortunately I didn't have the old printer i thought i did in the loft to smash apart for a suitable length so i'll have to visit Cromwells at the weekend for a section instead)
However in my attempt to try and do something productive i found a length of solid highly polished bar that was actually part of an old gearbox selector mechanism, which looks on inspection that it might be up to the job
So i clamped that in the jaws of the lathe and got the dti on it as close to the jaws teeth as possible. However i found that i was getting a 12 thou swing in readings as i rotated the jaw.
i then put the DTI on the edge of the chuck itself and found i got almost zero movement as i rotate it.
So i guess its one of 2 things
1) the bar i used is inaccurate
or
2) the the jaws are worn and not holding the piece centrally
or
3) both of the above
once i get a known accurate bar for measuring it should hopefully narrow down the source of the inaccuracy
i'm guessing a 12 thou variance so close to the head isn't very good?
I fi go on the assumption that the bar is ok and when i test again with the precision piece and i find the same variance, what are my options?
thanks
Matt
or
or
thanks
Matt
