Do you preheat?I weld 30mm thick trailer drawbar eye's on using 4mm rods at around 160-170amp. Your 200amp welder will do 10mm with ease.
This was single pass with a 4mm rod on that 200 amp Blackline mig/mma welder , turned up to max. That was a bit of 20mm plate, ultimately with thicker gear you are on multi passes.I weld 30mm thick trailer drawbar eye's on using 4mm rods at around 160-170amp. Your 200amp welder will do 10mm with ease.
Yes preheat. 7018s if at the workshop 6013s if on site.Do you preheat?
Presume 7018 rods...
