CGBservices
New Member
- United Kingdom, the Cotswolds
Just wondering if anyone has had this issue before and can point me in the right direction.
Gas is getting through to the unit absolutely fine, everything seems like it should arc up but there is no arc and no gas coming from the nozzle at all yet the wire is running perfectly.
I’ve checked the earth connection and the torch itself and the gas is coming through the regulator in to the unit so I’m a bit baffled.
I’d guess at an electrical fault somewhere. I’ve checked the connection in to the bottom unit and checked all the fuses in both units and still nothing is blatantly obvious,
The welder is a migatronic, I’m unsure of the model but if I need it to get a more accurate answer then I’ll update first this in the morning
