FAB
New Member
- Newcastle U.K
Hello all, hopefully somebody will be able to shed some light on the problems I am having with my genset.
I have an old diesel Arc-Gen Weldmaker 330sd. It has no guts on the low power anymore, just fizzles and wont arc up. It has power on the high setting but turning the current regulator (rheostat?) doesnt make any difference. 180A - 330A seems the same. Power to the 110v and 240v outlets still, both working fine.
The problems first started when I caught the earth cable melting and arcing off the job I was welding after rolling the hot job over onto the cable.
I tried to give it a service incase it was the fuel filter etc, but when turning it over and bleeding the diesel through it finally fired up and was revving way too high and wouldnt idle.
My friend who is a plant mechanic came and traced the wires back to a relay and fitted a new one which made the machine idle again, but still no welding guts on the low and no regulation of the amps on high.
I tried using it a little bit today on high power just tacking a few heavy plates with 3.25's and there was a rubbery burning smell from the set and when I switched it off the back of the positive terminal inside the machine seemed to be smoking? Almost like a dodgy earth connection in a cable would.
Does it sound like a faulty rheostat? Or even a dodgy earth/positive terminal? Hopefully something simple I can fix myself
Totally lost what to do, no body local wants to touch it or knows anything about it. Being a mobile welder I'm pretty stuck with out it too and I cant afford another machine right now.
Any help would be greatly appreciated.
FAB Mobile Welding
FAB Mobile Welding
