matt1978
www.lorch.eu
- UK, Cannock
Hey guys,
We are trying to Pulse mig weld 304L CrNi with 1.2mm 308L wire, 98%Ar 2%Co2 gas. When we weld the 20cm samples, everything is perfect, but when we go to weld the real job, I am getting an interferance in the arc, seems like magnetism. I have tried welding with 2 earth points on the job, I have welded, Left to right, Right to left and even changed the orientation of the job, but nothing is helping to solve the problem. I even changed from Pulse mig too Standard mig and I still got a problem. The joint is a I Beam, with 4 T-Fillets (8mm to 4mm) about 1.2 meter long (2 top, 2 bottom), sometimes you can weld 1 side without problems, next time we can only weld for 30cm and then we get problems. I can't think what else we can do too overcome this. Any ideas?? BTW the pieces which make up the I beam are Plasma cut and are tack welded using MMA, so out of desperation I even insisted that all sides that were to be welded were grinded first (bear in mind this is CrNi) and the job be tacked with Mig. The first two sides I welded were perfect, so I assumed that the problems were down too surface contamination and I had solved the issue, but when I turned the job over and started the 3rd joint, I got the same problems again!! I have changed, wire, Liners, Gas etc and still no joy. I am almost certain that its a build up of magnetism which is causing this problem, but was wondering if there was any tricks to overcome or minimise it. BTW where I am is very hard to get access to even the most basic consumables, so don't be telling me fixes which are gonna require any items out of the ordinary...... Any ideas??
Cheers,
Matt.
Cheers,
Matt.
