Are you aware of the 14point7 AFR gauges?This is for carb tuning, so i can see data when the engine is under load on the road.
diy-efi.co.uk
I wasnt aware of that, but it looks like just the kind of product I like. It's open source, comes from small, trustworthy manufacturer and considering quality I can deal with that price. Made in Canada, is a bonus at the moment.Are you aware of the 14point7 AFR gauges?
I came across them when looking for bits for a turbo conversion, but haven't used them. A bit cheaper than AEM, and seem to get favourable comments on various kit car forums (for the 'Spartan' version, at least).
UK distributor is DIYEFI (there may also be others):
14Point7 SLCFREE2 Wideband Controller & Optional LSU 4.9 Sensor
An ideal way to add full wideband air fuel monitoring to your ECU on a budget.diy-efi.co.uk
I've used 3 AEM widebands for 3 different turbo cars, also checked against the rolling road reference wideband, never a problem.aem ones are a bit sketchy so i dunno
whats the point using one at all if you cant trust it ? wouldnt expect it to last long but might be wrong
Yes, they usually have a sampling rate for the readout that's delayed enough to read and comprehend.How easy it to read a digital Air Fuel Ratio? I assume it'll be jumping around like crazy during road use? Will I be able to make sense of it?
