waddycall
- Cornwall
Mrs W took her 2010 Fabia 1.6 TDI (105) into the dealers today as it’s go an intermittent ABS fault. As part of the complimentary safety check they found that the flexi pipe coming from the DPF has separated from the DPF as the exhaust mount has broken, putting all the weight in the flexi. They want £1700 to replace the DPF. There is nothing wrong with the DPF itself just the pipe attached to it.
Does anyone have experience of removing the DPF on these? Is there a repair section that can be welded on? If it’s easy to get to I can think about doing it myself but I would be lying on my back in the gravel (and probably in wind and rain) or alternatively might take it to someone else to get it done but I would appreciate some impartial advice!
The cars done 130K so it’s not worth a great deal. The ABS sensor needs replacing which apparently means the wheel bearing as well as a bolt sheared off. They want another £400 for that.
It’s still at the dealers so I can’t look at it or take photos. It’s been maintained by them for the last 8 or 9 years so I’m a bit annoyed that they didn’t pick up the failing mount when it was last in a couple of months ago.
