It should be kind of straightforward you might think, but after welding some patches into the nosecone of my mates Fordson Major tractor I found it difficult to actually lose the welds and found the grinder was taking too much of the surrounding metal away leaving it quite thin. If I say so myself the patches looked nice and tidy after butt welding them into place, I didn't weld all the way around just gradually welded in between each spot weld until it was almost but not quite a continuous weld around the patch. The patch itself was level with the original metal and I used a 4" angle grinder with a flap wheel attached, not sure about the grit. Maybe grinding is as much an art as the welding itself and I need to perfect that too. It was just a bit frustrating after carefully making nice fitting patches and getting the welding part looking nice, to go and leave the metal thinner than it should be. I know the answer is obvious, take more care, but can anyone offer a bit of advice or a good technique to follow before I set about repairing the front of his other tractor.
Thanks in advance.
Thanks in advance.
I find coarse discs are actually easyer to use, as there's less 'polishing' of the harder weld; the flatdiscs dosn't tend to eat the soft surrounding metal rather than the hard weld. If that makes sense!? But you have to be a lot more carefull with a verycoarse discs to not 'drift' off the weld and grind the surrounding metal...
