My old fella is fitting a new kitchen. The new sink is shallower than the old one, and the worktop is slightly thicker.
This has contributed to the U bend / waste trap not lining up with the outlet pipe going through the wall.
The there is about a 1 - 2" gap between the bottom of the plug hole / waste fitting on the bottom of the sink and the U bend when it is attached to the outlet pipe.
Is there anything easily available to link the two?
The pipes are 40mm.
I've seen various things in wickes / B&Q such as adjustable waste traps, all in one waste traps / trap height adjusters but not sure which is most likely to work. It will get expensive if he buys loads of things which don't work and he can't take back because they have been opened / fitted etc.
Also are 1.5" the same as 40mm?
Cheers
Jim
The pipes are 40mm.
Cheers
Jim
