I thought little baler but couldn't quite figure out where it would goBaler ram
So that would be pushing front to back as such then to compress the bale rather than sideways across the baler?Plunger off a baler. The wooden bits are slides. Don't want metal to metal contact in a baler.
The masses had a bearing running on a trapezoidal rail, on the MF120 anyway. As I remember, you adjusted the rail to set the knife clearance but I could be imagining that. That one had suretie knitters using an epicylic gear too, very slick.The long arm connects to a gearbox behind the flywheel.
The material gets picked up on the reel, fed side ways and the ram pushes it to the back and also has a knife on it that trims it every stroke.
The slots in the main bit allow the needles to travel up through the ram to the knotter.
paint could be massey or international.
I'm sure bearings were also used instead of wooden slides nearest to the pick up reel.
Some makers used aluminium needles for the same reason.On a New Holland the feeding finger closest to the compactor was made of wood so that if the timing went out of sync it would cause minimal damage.
