CompoSimmonite
- Werrington, Staffordshire Moorlands.
I'm converting my Marlin Roadster kit car to suicide doors for better access (I have mobility problems).
The actual locks are going to be Spridget items as I've got a set left over from breaking a Midget years ago - knew they'd come in handy one day !
To be legal suicide doors require a method of ensuring they can't come open when the vehicle is in motion. You can get kits but they are little more than a manual sliding bolts whereas I want something automatic. That means some sort of additional solenoid operated lock. Problem, however, is it need to only lock when solenoid energised and automatically unlock when stationary / power fails / after accident and such. I thought taxi rear door units would work so bought a pair off eBay but they simply make the main door lock so it can't be opened rather than a separate fail safe lock as I require.
Yesterday I spent ages thinking about this problem as until it's solved I can't start work on exactly how the new doors will be made (Marlin has a blanking panel below the door hidden by running board that I'm removing so doors will be deeper as well as suicide).
Forget the control aspect at present - taxi will probably still provide a suitable speed sensing ECU.
Today I'm thinking a way around the problem could be adapting a pair of bearclaw locks so the latch spring keeps it open until a solenoid pushes it closed.
Any views, input, opinions etc appreciated.
Thanks.
Paul h
Thanks.
Paul h
