Charred fingers
I had a problem with the PCB on my Cosmo 130 and as I was thinking of doing a wire
feed conversion I decided to replace the entire board.
To do it I got a 15-24V variable output switchmode laptop PSU off
ebay, a 3 amp 18-24V PWM controller from Quasar electronics, and two
24V SPDT 16amp mini relays,a 2.5mm DC power socket, a 24V LED indicator
and a 10 amp terminal block from Rapidonline
I made up a board for the relays from a piece of plastic from a 20 litre
drum and used thin copper sheet from a scrap water cylinder to make the
tracking and copper wire to link into the terminal block
The relay board is spaced off the front case with nothing more than a
cut down H/D plastic pipe clip
The PWM uses the original hole and the plastic spacer washers from the
original board
The PSU is mounted on a stand which I folded from a piece of thin galv
sheet and riveted together
The 24V led is fixed in the original hole for the thermal cutout, you
do need to drill it out and I used the original knob for the PWM,
I shortened the shaft to match the original. The led is powered via
the output from the thermal cutout and is on as long as power is
going to the torch.
The photo's were taken before the finally wiring and don't show the wiring
of the main switch.
Briefly you remove the live feed to the original board completely, the neutral
and switched neutral go to the relay board. The 24V supply to the board is via the DC socket ,
the live out is split one goes to the PWM (note the PSU and PWM are powered up as long as the main switch is on)
the other goes to the torch via the thermal cutout. You remove the original return and thread a new wire up the torch
to carry the return to the relay board this is connected to the micro switch in the torch and is used to trigger both relays.
The power out from the PWM goes to the N/O contacts on second relay the feed to the motor is on the
common contacts . The neutral from the PWM goes to motor neutral and is linked to the N/C contacts on the relay.
Nearly forgot you remove the original motor neutral from the cluster near the transformer
The schematic as it stands now
Not a great pic anyone see any obvious errors.
Would like to thank everyone who has posted their mods which gave
me the imformation and the confidence to take this on.
original board
going to the torch.
of the main switch.
