Hi all, recently purchased a Clarke Mig 130 EN for two reasons other than just to weld - 1. VAT free weekend at Machine Mart and 2. I needed a welder I could run off a 240V 13amp supply.
Initially tried using the 0.9mm flux core (1.0mm tip) supplied with the unit but found that the flux causes lots of holes in the weld - frustrating. So I swapped it over to gas using 0.8mm gas wire (new wire) and Co2 shielding gas - much cleaner welds achieved - but only seem able to produce big (high) welds due to the wire speed - is this just me or is this typical of this type of welder. Today I swapped over to 0.6mm (old wire - dull appearance - not rusty) - didn't seem to get satisfactory penetration - I thought the smaller wire may give me a smaller better looking weld but it seems harder to weld with the smaller wire.
Also, my mini bottle regulator seems to be leaking slightly at the push-in connector - is this normal (due to the bottle pressure - 60 Bar?). Most pneumatic push-in fittings are only rated to 10 Bar. How critical is the gas flow?
Any advice would be great.
Mike.
Mike.
