Parm
Respect The Sound System
- Towcester
Brain is in overdrive and I think I've come up with an ingenious solution to make the type of heavy weight grill I'm after. So far plan is to use material I already have and not spend too much money, so to make the grill I was thinking of using 10mm square bar, drill equally placed blind holes into which I will insert cut lengths of 6mm rod. Slightly countersink the holes and then graze together. Then do the same on the other side and et viola, a self supporting grill that won't flex and last for ages
This may seem a bit complicated, but my welding skills are a bit naff and I only have a stick welder.
The question is can I brazen this ensemble together with only a propane torch, I have all the heads from ultra fine to big boy roofer style. And yes before you ask I'm considering brazing into a countersunk hole as I have a small chance of making it look neat. If not I will go with stick welding and spend hours with a pencil grinder to make the job look respectable
Thoughts, ideas, suggestions much appreciated
