This weekend thought I would do some welding. My motorbike had a few holes in the exhaust and i wanted to plug them up. The part was covered in rust and made out of mild steel. I got a wire brush disc and removed the rust. I then had a go at welding up the holes. I should state at this point that I have never done a good neat weld.
The area’s around the holes where so thin I just blew holes in the metal at the lowest power setting at the lowest wire speed. I moved a few mm away from the hole and did a spot weld to test and that did not blow a hole. So, I thought i would make my way over welding to the last weld. Total area to cover was the size of a 20 pence piece.
My issue was that the weld was just building up. I was not getting a nice pool, and if I turned the power up it would melt the wire back to the contact tip. More wire would just result in more build up. My welds where spotty and had holes in them. I was not achieving flowing metal. However, I was working upside down.
Also, when I weld thicker stuff on a bench I tend to have alot of weld building up. I am using 8mm thick wire in a Clark 160T, so i was think would 6mm wire make a difference to what I am doing?
Any comments welcome. My welding hobby is not going very well
