Hi all,
Haven't posted much so go easy on me (I have made a good effort at searching for similar posts though so hopefully I won't be repeating to much).
The weld set up at my structural steel company has always used Argoshield Light and I'm wondering after experiencing some difficulties in transfer changes if this (amongst other factors of course) is the ideal gas for this type of work or should i be looking at something heavier. I can get my settings dialled in nicely for the thicker gauge material we work on (spray transfer) but when I move to some of the smaller stuff (5-8mm) and i bring my settings down a bit my welds get awfully noisy and spatter starts to become an issue. Would i be right in thinking that a greater Co2 % helps in keeping spray transfer tidier due to better shielding? In which case would a Universal Argoshield be better? I appreciate that gas mix isn't the only factor at play here so i will take all advise and answer questions where i can. I use 1.2mm wire on a robust Murex Challenger 400.
Hope this makes sense and thanks
