Hi,
I'm new to welding so this probably seems like a novice question.
I'm welding up a "skid plate" (aka bash plate, or diff guard) for a 4x4. It's made of 5mm sheet steel. Basically a rectangle with some bends in it. I don't have any photos but here's a similar one (only made of aluminium):
The way I'm doing the folds/bends, is that I cut 3/4 of the way through the sheet steel with an angle grinder, bend it, and then weld up the cut.
What's happened, is that I did the cuts, did the bends, and checked that it fitted the 4x4 properly. It did. So I then welded it up. When I went to fit it again the angles had changed! I am guessing that the welds "pulled in" the angles (I've had this happen before).
I'm trying to think of ways to overcome this. Any suggestions?
1. Cut right through the metal and then weld on both sides, bit by bit, so that the "pull" cancels out.
2. Use some side braces to stop the angles changing (not ideal as the skid plate would then be too stiff - it needs some flex to absorb shock without transferring it all to the car chassis)
Hmmm?
Hmmm?
