Hi guys,
I have a 'Clarke 85en' that has a slight problem concerning the wire feed mechanism. Basically, the wire was not being fed through when pressing the trigger but the motor could be heard spinning.
I removed the wire feeding mechanism and dismantled it to see if any of the gears inside were stripped but they were all intact. However, I did notice that the small brass cog that is on the shaft of the motor is not securely fixed to the motor shaft, so the shaft spins inside the cog! I was thinking of applying some glue or loctite to the shaft as to keep the cog secured to the shaft because there is no other way of securing it. Was it secured with some sort of adhesive when manufactured? Hmmmmmmm....
Before I try to fix it somehow, I thought I'd come on here and get some suggestions or tips. I don't want to damage it further so any tips would be great.
Cheers guys... evad...
