KemppiFrog
- Aquitaine
Bit late in here, but I have been around boats since I was walking. Not so many steel ones, mostly plastic and wood. But Gwil not only has done it, but gives the best advice. Boats are very lightly stressed in general, except for point loads like rigging and rudders on sailing boats, as said, canal boats like yours are lightly stressed tin boxes and unlikely to suffer from weld failures . Can't think of a problem that wasn't caused by corrosion and usually internal. Since you are overplating, there are probably loads of examples right in front of you.
I was recently working on the systems of a Dutch built steel canal barge. The owner has spent the last couple of years scrupulously de-rusting the inside and époxy coating, cos he knows where the problem is. Boat is 70ft x 20ft and hull is 6 & 4 mm plate. 3mm would be fine on a canal boat, but the demon rust would find a way, hence replating with 25mm on the bottom etc.
A few yards from the barge, some guys were cutting out and replating a 35ft sailing boat. 4mm hull and rotted from the inside. They had an inverter 125amp welder and were using 2.5s with some tacks followed by a single pass.
Good luck with the boat.
Seems I am duty cook, so gotta go...
KF
KF
