Thanks for your reply. Polarity ok and gas supply ok. It does weld on stick so do you think the machine could still be bad?Check polarity by comparing with another machine - sometimes labels are incorrectly applied....?
Is pure argon gas supply ok?
If there's not even a glimmer of a spark machine is probably bad
Try Scratch Start - perhaps just the HF is down?Thanks for your reply. Polarity ok and gas supply ok. It does weld on stick so do you think the machine could still be bad?
If its a DC machine and its will produce power for stick, it will produce power for tig, you just need to suss out how to innate it , what methods of start do you have, HF, lift arc or scratch? I would set to tig mode and run through all the start types see what happens.Thanks for your reply. Polarity ok and gas supply ok. It does weld on stick so do you think the machine could still be bad?
