bigdry
Hello can anyone help? whilst trying to remove my lancia deltas oil cooler pipe,(as I need to replace the split hose section) due to corrosion and the effects of 20 years being fitted I tore the thread up on the cooler (it is alloy and the hose connector is steel...)
Basically I need a male fitting to weld on the cooler with external metric thread and internal tapered seat for the steel fitting to screw down onto.
The fittings are a little unusual in that they have a ball type end and need a corresponding matching seat on the weld on fitting.
Question is where do i get said weld on fitting from? I tried Pirtek but they dont know what the fittings are and dont do weld on fittings anyway?
The thread size is 1.5mm metric, the size is 20mm, can anyone help as im not getting very far with this on google...
