I’m constructing a shower cubicle on a narrowboat & planning to use aluminium for the walls with aluminium angle for strength/rigidity. Can you recommend thickness/grade and suitability?
One of the 3 walls will need to be bent into a shallow curve to conform to the outer steel wall of the boat.
I’m planning on using tread plate (for aesthetics) but this isn’t essential.
I’m planning on arc welding it together, but it doesn’t necessarily need to be welded to the steel hull.
Any advice you can give would be greatly appreciated.
Thanks
Thanks
