AndyStobbs
- North West England
I need to build up a damaged area of alu casting on my jet ski engine. Its a tricky position that would mean torch angle would be very low - 25 degrees. I have never tried Alu welding with the Mig and my TIG set is dc only.
Essentially if it was steel I would just keeping dotting blobs onto each other, it doesn't need to be neat and it doesn't have to be any stronger than just enough to stick. Its the circular apature where the starter motor pinion pokes into the engine, someone has drilled the original starter out - badly.
So is alu mig upto the job - in that can I keep blobbing bits together or will it all go south?
Thanks.
Thanks.
