Just after a bit of advice on heat sink materials.
I manufacture manifolds similar to the ones shown in this thread:
http://www.mig-welding.co.uk/forum/showthread.php?t=23592
However mine are aluminium. The baseplates are 10mm thick, the tube 3mm thick either 45mm dia or 51mm dia.
I run a 200A AC inverter machine. To achieve the fillet to the plate I use a 3.2 tungsten (was using white tip, now trying grey).
To minimise distortion I fasten the assembly down to an aluminium plate using the actual manifold fastener holes. I find this works well and means the workpiece is very easy to manipulate without lots of large clamps etc. So I have a couple of different plates (15mm and 25mm thick - just what I had lying around) with lots of holes drilled for the variations in manifolds.
I do however find that I am almost continually running at 200A (so the limit of my machine) to do the fillets. Does 200A seem about right for this type of work? I wondered if I would be better or worse off changing the material of the heat sink plates? Would I get heat into the job quicker if I used steel plates and thus achieve a more consistent weld? - the initial welds are hard work (slow moving, poorer appearance) until the workpiece has heated. I am not preheating purely due to lack of facility.
I guess the obvious answer is to address the pre-heat issue.....
My products are (I would like to think) of reasonable quality and appearance, but I am always looking to improve. Any advice would be appreciated
