mike os just a little insane..... Messages 9,809 Location North Wales May 14, 2018 #1 If need some c section with a 5 to 6 mm slot to take an m4 screw head any idea where it will get some? Google is not being very friendly
T tlovatt Member Messages 1,184 May 14, 2018 #2 If you search for 10mm by 10mm channel you should find it with a 2mm wall thickness. https://www.aluminiumwarehouse.co.uk/aluminium/channel This should give you a 6mm ID
mike os just a little insane..... Messages 9,809 Location North Wales May 14, 2018 #3 tlovatt said: If you search for 10mm by 10mm channel you should find it with a 2mm wall thickness. https://www.aluminiumwarehouse.co.uk/aluminium/channel This should give you a 6mm ID Click to expand... That's channel not c section
bigegg Scream Not Working Because Space Make Deaf Messages 9,648 Location Leeds, West Yorkshire May 15, 2018 #4 ? Do you mean t-track? Because I thought c-channel = u-channel = channel?
T tlovatt Member Messages 1,184 May 15, 2018 #5 If you want something that will keep the bolt heads captive then as above, it is called T-Track, C section is channel. I have never come across T-Track with a 5mm to 6mm slot width, you will end up with very small contact area on the bolt head?
