Screwdriver
I need to repair this aluminium part, probably by cutting off the distorted threaded spigot.
Clearly the item has failed in service, I guess by being over stressed. I assume the remaining part will be compromised so plan to chop it off and build up in weld.
Question is, since this part has already failed, is an aluminium build up going to be strong enough? Pretty sure I have regular 4041 rods and am confident I can build up successfully, tying into the part before machining down to size. I really don't want to have to make this part from scratch.
Is it better to cut the bent/fatigued part off or will it regain its structure if I were to weld onto it? I probably will have to at least cut half the thread away so that I can get right down into the bottom of the threaded hole. But I assume it will be much easier to build up from the remaining half than welding onto thin air.
Will such a repair be strong enough and how else might I effect a repair, rather than make new?
S.
S.
