Hi has anyone any experience using of Alumfix rods
https://www.facebook.com/AlumifixWeldingRods/
I used lumiweld rods to fix a nigh on impossible to replace oil filler horn on my old motor. The horn was an aluminium alloy of un’known composition & the break had to cleaned with a stainless steel brush (supplied with the rods). The lumiweld made a superb job of rejoining the the broke pieces. The only down side is the lumiweld metal is very hard & cleaning up the joint was a bit of a chore.
RonA
Did you just use it with propane, or does it need a hotter flame like oxy-turbo?I like this new swear filter.
yes all under different names and they work very well with a bit of practice as in post 6 the welds are very hard but not a problemAre they the ones you sort of stir the pool with, like Durafix & Lumiweld.
me tooI'll have some of what you're drinking.![]()
I don't bother going on Facebook but if people say they work well and are good believe it they areseen all the ads on facebook never seen them in real life, I dont believe all those adds on FB TBH
The repair was made using a plumbing propane torch. The hotter you can get the workpiece the better the lumiweld flows. As mentioned the lumiweld material is hard as hell & it took a fair amount of filing & emery cloth to get the repair looking tidy.Note to self: I do NOT need another process to experiment with!!
Mind you, it doesn't cost the earth......Did you just use it with propane, or does it need a hotter flame like oxy-turbo?
