Hello all,
I was wondering if the most-experienced in metalwork on the forum could sort out the jargon that's always running around in my head about the kind of alloys used to make the tools we use - from the simple hacksaw blade to the most expensive milling cutter. Please note - all tooling refers to metalwork.
General purpose hacksaw blades are made from high carbon steel - now I've come across molybdenum blades.
Drill bits are mostly high speed steel - I also came across titanium coated high speed steel and now it's high speed steel alloyed with cobalt.
Hole cutters are mostly bi-metal. Now there are tungsten carbide ones.
HSS, molybdenum, bi-metal, bi-metal+cobalt, carbide, tungsten-carbide, titanium, ----the list is endless. The cutters of super alloys are becoming more and more expensive and you'd have to know what you're talking about to keep up with the times.
As a simple example, I bought titanium-coated drill bits for experimenting. The coating does make then a retain their sharpness slightly longer ...but in the long run I guess the initial cost isn't worthed cos they will dull up in the end and when you sharpen them, you also remove the titanium coating, --which leaves you with a regular HSS drill bit.
What do you normally use? What works best for you? Is what you buy really worthed the initial cost of the alloy? Of all the alloys above, which is the most cost effective one for a cutting tool? Do you understand the advantages (and dis-) of using an alloy compared to another? If you know, then please explain and share with me so I won't keep scratching me head at shops.
