SmartWerks
pre-moderated
- chester
Thanks for the info hotrodder.
You can cure at higher temps for a shorter duration but there isn't much in it really, getting the part to temp is the longest part of the cure process so no real advantages curing at a higher temp and I don't believe it is common practice as there isn't any benefits cost and production wise.
As for forged wheels, i believe they are treated at 800 then 400 degrees and the temp required to weaken the alloy is way above the temp required to cure powder. I can't speak for magnesium wheels, hit and miss with regards to war page but they shouldn't if the correct temp is used. But a lot of coaters rely on methylene chloride based strippers which will eat the mag. The blasting required to strip wheels prior to coating can cause heavy pitting which means a lot more prep work and the sort of job you will lose money. From what i have read on mag wheels I wouldn't be happy coating them, to risky and a lot of money to replace and don't have the necessary experience.
