Hi all....saw an add/video on facebook showing using ali rods with a blow torch....seemed to be welding steel as well as alloy.
The website says for welding cast iron engine manifolds.
Is it possible that you can weld/braze the metals with these rods....here is the web site.
I have a mig/arc/gas.
www.delighter.co.uk
Solution Welding Flux-Cored Rods
Why Welders, Mechanics, & Household Handymen are calling Solution Welding Rods "The Strongest, Fastest, and Easiest Aluminum Fabrication or Parts Repair– no expensive equipment required. Does The Impossible. Makes a sound joint with slight penetration to base metal that is stronger than mild...
