A a.k.jain New Member Messages 1 Mar 3, 2009 #1 I want to run 1.6 mm Al MIG wire on my 350A ( 60% duty cycle).will it work as current and wire feed are controlled by same button . Do reply earliest possible.
matt1978 www.lorch.eu Messages 3,966 Location UK, Cannock Mar 3, 2009 #2 Hello, Are you going to run in standard spray transfer? What is the reason that you want to use 1.6mm wire, 1.2mm should give very good results. What grade of filler wire?
A ashish jain New Member Messages 4 Mar 3, 2009 #3 re al 1.6 wire Dear Mr Matt, Due to my agreement with party I want to switch over to 1.6 mm wire.Will it be possible ?
madkayaker Pro sparkey Pro Welder Messages 13,678 Mar 3, 2009 #4 what machine are you useing? What thickness are you welding
matt1978 www.lorch.eu Messages 3,966 Location UK, Cannock Mar 3, 2009 #5 Yes it is possible, But...........how thick is the material that you want to weld? Is the machine, Synergic Pulse or a inverter based standard mig? I only ask, because the voltage (and material thickness) required to run spray arc on 1.6 mm wire is quite high.
