Mutley7370
New Member
- Norfolk
Evening all. today was spent reinforcing a 3.5 tonne trailer - we added some box section cross members etc. in doing this we rolled it over to weld the underside of each joint, at which point I noticed the welds on the Al Ko axles were cracked about half way around. (Where the axle box section passes through the bracket which bolts it to the chassis)
This trailer is used for a lot of off roading and firewood collection out of forests so it has had a hard life. It would be an easy repair to weld the cracks but for one problem, the rubber suspension bushes would be destroyed. Knowing these axles are firghteningly expensive, does anyone know if they can be stripped out and re-bushed, as we could strip out the old bushes, grind out and weld the cracks and then rebuild with new rubbers etc.
We had a quick look tonight but can't immediately see how the axle comes apart. Anyone out there got any ideas or knowledge on these things??
