If you have the gas & reg, there is only one way to find out.
Reversible tools fetch a higher priceI have a bottle of propane. But the regulator is left hand thread, so would the tool go backwards?
Not only that, it will have an inbuilt light, like all that modern stuffI have a bottle of propane. But the regulator is left hand thread, so would the tool go backwards?
An inbuilt? What's that?Not only that, it will have an inbuilt like all that modern stuff
sensible ideafit a shrader valve on the whip and take them to the garage forecourt and plug em in to the tire inflator![]()
What pressure do air tools like sanders and grinders run at ?
They'll probably spin up at 60psi though which is the most I've seen CO2 regs go up to though, should be enough to verify they work.90 psi
