rtbcomp
Moderator
- Sheffield UK
Just because you pump 40 psi into the mask doesn't mean the mask pressurises to 40 psi. It doesn't, the air escapes and keeps the pressure down. You need the high pressure to shift the volume through an airline.
You could always use an oil-less diaphram compressor, but it would need a 100% duty cycle. You'll still need a water trap though.
You need sufficient flow to keep the mask at a resonable pressure and you still need a good seal round your face, otherwise polluted air could still get inside due to turbulence.
