Hi, first post here.
I spray paint occasionally (hobby) - some 2k.
After reading some of the stories about 2k on this forum, I bought a Iwata air-fed kit - it comes with a carbon filter and hose.
As for 3 stage filter sets, there's the devilbiss (very expensive), the Deltalyo/Kestrel and I've also found (cheaper) "Metalwork" and "Transpower" (on Ebay) branded sets. Does anyone have experience with the cheaper options?
I'll be using the mask with one compressor and a separate compressor to run the spray gun. Where do I put the 3 stage filter, closer to the compressor or the mask?
Can I run a 15m hose between the 3 stage and mask?
Can I use a standard hose between the 3 stage and mask (provided that it's new, and is never used with other compressed air tools/guns)?
Is this setup acceptable: 3 stage filter close to the compressor, followed by a new 15m hose to the face mask's carbon filter, and then run the supplied hose to the mask.
Anything else I should add either before the 3 stage filter set or between it and the mask's carbon filter?
Thanks for reading, and any help you may provide.
Zeca
Zeca
