danelectro
I can't believe you just said that, considering you're a "Senior Member" on this site i find your comments disgusting.
This stuff is lethal, and can cause SERIOUS LONG TERM HEALTH problems, and your advice is basically "get a good lung full and if you feel a bit sickly then your gear is dodgy"
Firstly, you don't "feel a bit sickly" what happens is: you can't get a breath, which slowly gets worse to the point where breathing is impossible, then you go to hospital and end up on oxygen, then medication to control your OCCUPATIONAL ASTHMA for the rest of your life.
Secondly, as far as Air fed masks are concerned. There is info stated that comes with the mask that tells you what equipment should be used (i.e. Minimum CFM of comp, filtration etc etc) and the carbon filter has a shelf life and MAXIMUM number of hours it can be used.
No, you're right, it's not bomb proof. but this info is based on full blown trials in lab conditions and not using human beings as the testers.
After all that has been said about 2K and air fed masks, you should be really ashamed of yourself. and as said above, considering you're a senior member, you must remember that many people may take your word as the gospel. Absolutely shocking.
