RaceDiagnostics
- Broughty Ferry
I had my air con refilled a month ago but its cut out again so a fairly big leak. Can anyone recommend a refill that has dye included that I can use a UV torch to find the leak.
Had mine done at ATS but it just gets cold .i dont have a clue what they put in....ATS stuff should have it in there....well mine did anyway
does sent a propane flame change colour when held near a leak i seem to remember an industrial refridgeration guy showing meI do a 150 psi test with Nitrogen
If the pressure holds the system is put under vacuum
Then refilled with refrigerant as well as a quantity of lubricant and the green dye
A small leak can be very hard to find
It is normally the condenser at fault
To be honest this is why places like Halfords etc shouldn't be allowed to refill aircon systems, it's a specialist job that to do properly takes time. Anywhere offering "Air con refill for £30" can't be doing a proper job. Since yours has leaked out in a month or so unless some component has just failed that should have shown up when they tested the system prior to refilling.I had mine regassed a month or so ago but the ac stopped working yesterday, the fault code shows low pressure. I checked last night with a UV torch but nothing showed up.
I had a look at the ATS but it doesn't say anything about dye.
I checked the Halfords gas but it doesn't have any dye in it either. Looks like I will need to call in a specialist.
Wouldn't advise that trick with some refrigerants...they are very very flammable
would i be right in thinking it was called R32 it was fixed and filled up with reclaimed gas years ago, then they changed it to something more eco friendly
Car stuff here used to use R12, was then R134a and now is a myriad of stuff including R1234yf (flammable horrible stuff)
Thats coz they used coolin gas not heating gasHad mine done at ATS but it just gets cold .i dont have a clue what they put in....
How much did that cost?? My nissan navara has a leak but i dont know where.Ok got it pressurised with nitrogen and found a leak in the condenser, that will be a pain to get out. It also turned out there was dye in it already.
The guy only asked for £20 but I gave him £25 cash, he was here for about 30mins, he did also get 93grams of my refrigerant for free. He measured the weight as he pumped it out into his bottle.
