Well I've got a project i've been working on and its came to abit of a stand still. The problem is i have fitted another motorbike swingarm onto my bike, so all that was left was to make a lower shock to frame mount.
So i made a bracket out of 5mm thick metal and the problem is i'm only getting about 4mm penetration out of my mightlymig 150 (which i found out is pretty much max after melting my torch internals).
So the way i see it is i have 3 options:
option one: i'm not 100% keen on, so i've drilled thru the bracket and frame and bolted them together. but it leave doubt in my mind on safety!
option two: I think is the only real option but been advised 5mm should be min.
option three: Not an option due to lack of current funds, and its a expense for a one off job!
so I thought i'd like to get you good people's view on my options.
- continue welding with 4mm penetration.
- reduce bracket thickness to 4mm.
- buy a bigger welder!
