Where'sMyBrew?
Hi
As an DIY amateur, I need your collective wisdom please. Below is a pic of a fractured lower door hinge on my VW van. I suspect at some time in its life, this hinge was cut and welded (poorly), hence this straight line fracture, which occured under strain after several days of bedding in a new door seal.
The hinge bolts onto the A-post, but is riveted onto the door from which it can't be easily be removed.
I've a Portamig 215. I've not measured (yet) but I guess the the hinge is 4 or 5mm thickness.
I'm conscious I've got to be very careful with the heat to make sure I don't warp it the door gaps were all perfectly aligned prior to the fracture, so I need to ensure the hinge doesn't alter position relative to the door.
In terms of an approach I was thinking along these lines:
- tack weld top and bottom faces whilst in situ on the van to ensure fracture lines up perfectly
- remove door from van
- bevel a V-channel along the front facing line of fracture using a dremel. 3mm width ?
- slowly butt weld along this channel with short runs of 0.5 cm, plenty of cooling time inbetween to avoid heat build up
- once front is done (and stone cold), bevel a v-channel along the rear of the fracture and repeat.
- grind down welds, skim filler and paint....
oh, and I also want to (hopefully) avoid damaging the paint on the door itself.....
I'll have a practice on identical metal before hand.
any advice much appreciated.
cheers
Gareth
cheers
Gareth
