medroberts
Hi Everybody,
I have a kemppi KM 400 mig, which I need some help on setting voltage/wires speeds. I have downloaded the manual from the kemppi web site. Iam using 1mm wire and argoshield @12LPM. I have been on the Miller website and tried using there free calculator. I set the mig to 30 volts(spray transfer)/9.8metres/min(386ipm) on 12mm plate. I had problems when striking the arc, the wire would burn back to the tip and then jam the feed ? When the arc could be maintained the display only shows just over 200 amps ! The weld appearance does not seem to have penertrated as I would expect (hasnt washed into the steel) Is there anybody with experience of my machine or point out were Iam going wrong? Settings etc
