Was working on the car last night, removing the manifold to replace a leaking gasket, then while under the car I noticed the bracket on my s/s downpipe has come clean off.
Pics as follows.
Hole in exhaust...
Broken off bracket....
Bracket lined up with the crack....
You can see in the picture it's a perfect fit, except for a 5mm hole at the top that I can fill with weld. There is also a hairline fracture going from that 5mm hole vertically up towards the flange that I would like to weld over to prevent getting any worse.
I know I'll need to grind back to clean metal on both the exhaust & bracket. I have a Clarke 151TE with the original spool of wire it came with, the original CO2 canister it came with and I also bought an Argon/CO2 canister when I bought the welder that has not been used yet.
Is welding stainless the same as welding mild steel? Should I use the Argon/CO2 mix instead of pure CO2? Do I need new wire, etc? I have had to order new tips, so can't do anything until they arrive and will order other supplies I need today/tomorrow if needed.
Oh, what wire speed & power settings would you recommend for this kind of job?
Cheers!
Pics as follows.
Hole in exhaust...
Cheers!
